1990 Oldsmobile Ciera engine turns over but won't start
1990 OLDSMOBILE CIERA
BRIAN 59V
  • 4 POSTS
Electrical problem
1990 Oldsmobile Ciera Front Wheel Drive Automatic
The injectors won't let fuel through,I disconnected the injector wire, turned key to the on position, checked for power and I have power to both sides of the connector. Than I unhooked all the senors and I still have power on both sides of the connector. I disconnected the battery and reconnected it and it's still the same.
May 19, 2010 at 7:15 PM
Sounds like the computer injector driver circuit
May 19, 2010 at 7:17 PM
BRIAN 59V
  • 4 POSTS
Thanks alot. Does that mean I need a new ECM?
May 19, 2010 at 7:29 PM
That's where its pointing at
May 19, 2010 at 8:30 PM
BRIAN 59V
  • 4 POSTS
I took out the ECM,but I still have power at both sides of the injector connector. I checked the voltage at the battery I have 12.6 volts and at the connector of the injector I have 11.8. Dosen't the injector get its power from the ECM? I also disconnected the ignition module and still have power at the injector plug. The more I work on this car the more confused I get!
May 20, 2010 at 11:49 PM
