1988 Oldsmobile Ciera FUEL CONSUMPTION
1988 OLDSMOBILE CIERA
157,000 MILES • 6 CYL • FWD • AUTOMATIC
JJKJ
Hi, my 1988 Olds Cierra started using excessive fuel. Had injectors cleaned, new spark plugs, checked plug wires. Recently had new catalytic conv. and muffler put on. Could my problem be the fuel pressure regulator & if so what should the normal pressure read. Thank you for any help you can give.
Apr 25, 2009 at 6:44 PM
Checking the fuel pressure you can rule out a defective fuel pressure regulator with and w/o vacuum to it and a clogged return line-
TBI fuel pressure 9-13psi
PFI could range from 60-90psi
Apr 25, 2009 at 7:04 PM
