[quote:b56275dda6="ImpalaSS"]Hello – sorry you are having problems with the car
If I understand you correctly, the car died just sitting there idling. When you say you tried to start it, the starter was turning over but it wasn’t starting? Or you turned the key on, the dash light came on but nothing happens?
I am going with it was turning over (correct me if I am wrong) – you noticed the white smoke out of the intake.
Have you been loosing any anti-freeze? How much is in there now?
If the engine is turning over, then remove the oil filler cap. You need to be able to see inside the valve covers to see the lifters. Have someone try and start the car – the belts should be spinning….while they are spinning look inside the valve cover and see if the lifters are moving up and down.
If you are able to pull codes that would be great. You could go to Auto Zone or O’Reilly’s and for free they can pull the codes to the car. Most important. Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for free also they can bring their tester out and check your battery, alternator and starter.
If not – let me know what you find out with the above. Also, please be specific on your car…there are several to choose from. Is your just a Ciera, or is it a Ciera Cruiser? It is a V6 but is it a 2.8L or 3.8L….please be specific here.
Thanks and let me know
Thank you very much for the donation.
Find a car repair manual for your car repair questions.[/quote:b56275dda6]
yeah it just died about 5 seconds after i got out and its a 3.8 v6 cutlass cierra brougham vin 3.
i know im not losing antifreeze tho. i was thinking it was the mass air flow shorting out and causing the smoke in the air intake, its a vane type sensor.
i did check for engine codes however with a paper clip since its an OBD1 system and i never got any codes other than code 12 and ive never had the SES light come on while driving either. it still comes on with the key in the on position tho.
and also i notice a slight smell of gas from the engine after trying to start it a few times.
the car was sitting for about 5 months with a dead battery, but i got the battery charged and started it right up about 3 weeks ago and its been running fine until now
Nov 2, 2008 at 3:46 PM
