1987 Oldsmobile Ciera code reader
1987 OLDSMOBILE CIERA
APARKER1022COMCAST.NET
  • 12 POSTS
Engine Performance problem
1987 Oldsmobile Ciera 6 cyl Two Wheel Drive Automatic
i have a code reader, it is compatible with my car but im only gettin one code which is the "system pass" code. why wouldnt it be giving me codes? what can i do to fix this?
May 18, 2010 at 3:56 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
If there are no set fault codes in the system this sis what you will get, to test the code gathering ability of the ECU and the reader. induce a code, say unplug the TPI and start the engine and try to rev it, this should set a code to read.
Mark (mhpautos)
May 18, 2010 at 5:22 PM
  • 12 POSTS
what is a TPI?
May 19, 2010 at 12:55 PM
MHPAUTOS
  • 31,937 POSTS
TPI. Throttle position indicator, that is the sensor at the throttle body, i used that as an example as it is easily access to unplug to see if the reader will read any code.
mark (mhpautos)
May 19, 2010 at 5:29 PM
