Engine Performance problem
1987 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic
1987 olds cutlass 3.8 litre.good fuel pressure,no spark.i replaced the crankshaft and camshaft sensor,still no spark.i have a good battery voltage at the crank sensor connector(harness side).i have a good 5 volt reference at the crank sensor,also a good ground.if i take a test light and touch the 12 volt wire( harness side),the coil fires spark.if i touch the 5 volt ref. wire with the test light the injectors fire.i plug the connector back in to crank sensor,still no spark or injector fire.?
Jul 17, 2009 at 3:39 PM
