1986 Oldsmobile Ciera obvious short going to starter soleno
1986 OLDSMOBILE CIERA
M. TIMBERLAKE
Electrical problem
1986 Oldsmobile Ciera 6 cyl Front Wheel Drive 120000 miles
Turn key,click.Wiggle wires on back of starter solenoid,start.Both -& +battery cables replaced.
Jun 10, 2010 at 11:41 AM
INTERNETMECHANIC
  • 700 POSTS
The purple wire at the starter solenoid S terminal goes hot with the key in the crank position. Without wiggling anything, is it hot? If not, back track the circuit till you find voltage, splice in a new wire and connector, if that is the problem? If you short the solenoid bat terminal to the solenoid S terminal, the starter will crank, even without the key. Make sure the tranny is in park or neutral and the e-brake is set, when trying to crank. There can be safety issues trying to crank that way.
Jun 10, 2010 at 12:15 PM
