2003 Oldsmobile Bravada AC Fan
2003 OLDSMOBILE BRAVADA
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
VINCENTJC
  • 6 POSTS
The air condition fan works only on occasion, usually when I start the car in the am, then after shopping and starting again, it will not come back on.
The A/C itself is working and air blows in from the outside as a result of moving, but no cold air if I am stopped.
It also will not adjust speed, it is either high or none at all.
The outside temperature display reads 50 even if it is 100 degrees outside.
Jul 23, 2010 at 1:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
as for the blower motor issue, it would seem as though either the blower motor relay or the blower resistor pack has failed.
for the temp. reading, it is caused by a faulty ambient temperature sensor.
Jul 23, 2010 at 5:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sure, your ambient air temp. sensor is on the left center of the radiator support.
Jul 24, 2010 at 12:27 PM
