2002 Oldsmobile Bravada turns over but won't start
2002 OLDSMOBILE BRAVADA
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRKREID70
how to determine problem
Apr 16, 2010 at 10:08 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 16, 2010 at 12:50 PM
