2002 Oldsmobile Bravada alternator replacemnet
2002 OLDSMOBILE BRAVADA
DALE LA
Electrical problem
2002 Oldsmobile Bravada Four Wheel Drive Automatic
How do you replace the alternator
Feb 24, 2010 at 2:03 PM
TOOOMANYTOYS
  • 513 POSTS
Disconnect the battery negative cable.
Remove the drive belt.
Disconnect the battery positive cable nut (1) on the generator.
Remove the A/C line mounting bracket bolt at the engine life hook.
Remove the right engine lift hook bolts and remove the lift hook.
Remove the 3 generator mounting bolts and remove the generator.
INSTALLATION PROCEDURE
NOTE: Refer to Fastener Notice in Service Precautions.
Install the generator and secure the generator with 3 bolts Tighten Tighten the generator bolts to 50 N.m (37 lb ft) .
Connect the battery positive cable to the generator and secure the positive cable with the nut Tighten Tighten the generator positive cable nut to 9 N.m (80 lb in) .
Install the engine lift hook and secure the lift hook with 2 bolts. Tighten Tighten the bolts to 50 N.m (37 lb ft) .
Install the A/C line bracket to the lift hook and secure the bracket with the bolt. Tighten Tighten the A/C line bracket bolt to 10 N.m (89 lb in) .
Install the drive belt.
Connect the battery negative cable.
Feb 24, 2010 at 2:10 PM
