Transmission problem
2001 Oldsmobile Bravada Automatic 150000 miles
Just changed the sun shell in the transmission. The vehicle drives perfectly forward but will not move when shifted into reverse and you can not push it backwards in neutral. Initially the vss sensor and the propshaft sensor were switched around so I drove it for about a week with no speedometer. I took the oil pan, filter and transmission valve body off to inspect the check balls and then realized the sensor plugs on the transfer case were switched around. I put everything back together and switched the sensor plugs to their correct positions. The vehicle now works properly except for the above conditions. When I put the Bravada in reverse it sounds like it engages it just won't move. Any ideas?
May 15, 2009 at 8:38 PM
