How many miles are on this vehicle, and have you ever experienced this condition before? It could be as simple as the wrong fluid in the transfer case. There was a new fluid released from GM in about 2005, it is called auto trak II, and is blue in color. A revision to standard auto trak fluid which was red. There is a bulletin on this, that includes your model year. It could be as simple as a fluid change, or as complex as an internal transfer case repair. The fluid change would obviously be a recommended starting point.
Here is a copy of that bulletin.
#99-04-21-005E: Transfer Case Shudder (Flush and Replace Transfer Case Fluid) - (Nov 28, 2005)
Subject: Transfer Case Shudder (Flush and Replace Transfer Case Fluid)
Models: 1999-2005 Chevrolet Astro (AWD)
1999-2005 GMC Safari (AWD)
1999-2001 Oldsmobile Bravada
with All-Wheel Drive (NV136) Transfer Case (RPO NP4)
This bulletin is being revised to update the correction information. Please discard Corporate Bulletin Number 99-04-21-005D (Section 04 -- Driveline/Axle).
Condition
Some customers may comment on a vibration (shudder) during tight turning maneuvers on dry pavement at vehicle speeds less than 8 km/h (5 mph).
Cause
This condition may be caused by a slip-stick of the clutch plates in the transfer case clutch pack. On 1999 to 2002 models, the preload that is designed into the clutch pack may contribute to the condition. In addition, contamination of the fluid may interfere with the friction modifiers.
Correction
Flush and replace the transfer case fluid on affected vehicles using the following procedure and the part number listed below.
Perform the following diagnosis prior to flushing and replacing the transfer case fluid in order to properly identify the shudder.
Diagnosis
Verify the shudder in the vehicle. The vehicle needs to be at operating temperature (driven at least 8 km (5 mi) for proper diagnosis. After the vehicle is at operating temperature, drive in a tight circle just short of steering wheel lock, at a speed less than 8 km/h (5 mph) in order to identify the shudder.
Identify what rear axle type the vehicle has.
• If the vehicle has a standard rear axle, then proceed to step 3.
• If the vehicle has a locking rear axle, remove the front propeller shaft. Refer to the Propeller Shaft subsection in the Service Manual. Drive the vehicle as outlined in step 1.
• If the shudder goes away, install the front propeller shaft and proceed to step 3. Refer to the Propeller Shaft subsection in the Service Manual.
• If the shudder does not go away, the locking rear axle may be the cause. Evaluate the condition using diagnostic information in the appropriate Service Manual.
• Install the front propeller shaft. Refer to the Propeller Shaft subsection in the Service Manual.
Flush the transfer case with the blue colored fluid (AUTO-TRAK II) using the procedure and part number listed below. Perform the flush procedure even if the transfer case contains the blue colored AUTO-TRAK II fluid in order to remove any possible contaminants. The AUTO-TRAK II fluid contains an improved friction modifier that should correct the slip-stick condition. Refer to the Transfer Case subsection in the Service Manual for information on draining and filling the transfer case.
Flush Procedure
Important: Refer to Corporate Bulletin Number 99-04-21-001, dated April 1999, for important information on removing the transfer case drain and fill plugs.
Drain the transfer case fluid.
Refill the transfer case with 2 L (2 qts) of new fluid, P/N 12378508 (Canadian P/N 10953626).
After refilling the transfer case, drive the vehicle a minimum of 8 km (5 mi).
With the transfer case at operating temperature, drain the transfer case fluid again.
Refill the transfer case with new fluid.
Important: The vehicle may require approximately 160 km (100 miles) of driving before the condition is completely corrected.
If this procedure does not correct the shudder condition, please call the Technical Assistance Center for further instructions and review PIP3012D or newer.
Parts Information
Part Number
Description
Qty
AUTO-TRAK II Transfer Case Fluid
4 (1 L) containers
Jun 4, 2010 at 11:38 PM
