I have a 2000 Oldsmobile Bravada. I just literally got the car back today where, after the A/C, brakes, and a window with power issues was worked on. They drove the car here so it was working before.
I decided to see how the car would run, so I tried starting the car. At first, the car had trouble starting (it is semi-normal, its had this issue in the past and the water pump was recently replaced). I waited a little bit and then tried starting the car again. This time, I had power since everything (a/c, radio, lights, ect) was working, but my starter (I believe, may be wrong) made a rapid clicking noise, same noise as when a car battery was dead. I gave it a few minutes, same thing.
I went inside to grab a couple things before coming back to the car, and my electrical system was all messed up because things were randomly turning on even though the car was not on and I had the only key (I know sounds like I am making this stuff up but I am not). Then, my battery went dead soon after.
Tried using another car to jump my car, but after 15 minutes my car still did not show an ounce of life. I know for a fact that I did not mess up the cables jumpstarting the car since I triple checked and I've jumpstarted a car before.
If it is relevant, this car was sitting unused in my driveway for at least 3 months due to overheating and a coolant leak, which I finally got fixed. Now, I'm in a cycle of getting this car back and it starts failing as soon as I get it back.
Any help or ideas would greatly be appreciated, hopefully I can get this thing running.
Mar 18, 2017 at 9:18 AM
(Merged)
