2000 Oldsmobile Bravada distributor and timing
2000 OLDSMOBILE BRAVADA
BIGBOB42
Engine Mechanical problem
2000 Oldsmobile Bravada 6 cyl Four Wheel Drive Automatic
where is the dial for the timing located at on the block. and how do you install the distributor as well..help...please...asap
Dec 27, 2009 at 11:05 PM
BIGBOB42
[quote:690531db9c="bigbob42"]Engine Mechanical problem
where is the dial for the timing located at on the block. and how do you install the distributor as well..help...please...asap[/quote:690531db9c]
tried and no luck with chilton or any of them...
Dec 27, 2009 at 11:09 PM
