1999 Oldsmobile Bravada headlight switch
1999 OLDSMOBILE BRAVADA
62,500 MILES • 6 CYL • AWD • AUTOMATIC
EYEBURIUM
Gentlemen-
My 1999 Bravada light switch will not turn off. I cannot switch from off, to dimmers to headlights. The inside cabin swith is not broke. They are constantly on. Do I have a loose wire issue? all lights work, just can't turn them off.
Ron
Dec 11, 2008 at 3:17 PM
SWILLIAMS
  • 597 POSTS
Sounds like the automatic light sensor has failed or is covered. Look at the right hand speaker for a small plastic lens that sticks up. That is the sensor. If the fail the lights usually stay on as soon as you turn on the key.
I have also seen them get knocked into the hole they snap into. That causes the same thing.
Dec 14, 2008 at 7:21 PM
