1998 Oldsmobile Bravada setting tilming
1998 OLDSMOBILE BRAVADA
200,000 MILES • 6 CYL • AWD • AUTOMATIC
NASHCRAFT
removed distributor to put on intake manifold gashets.
put distributor back in to i thought removal position.
engine did not run well.
brought engine up on compression stroke on no 1.
aligned dampener mark with V tab on front cover.
set distributor in with rotor as close to no. 1 as possible. (tried other tooth settings) engine dose not start good. runs terrible. checked code p1345, misfire stated by scanner.
need suggestion
norman
[email protected]
Aug 20, 2009 at 10:26 AM
If you turn the distributor, can you get it into time?
Sep 15, 2009 at 1:27 PM
