1998 Oldsmobile Bravada oil
1998 OLDSMOBILE BRAVADA
109,000 MILES • V8 • AWD • AUTOMATIC
DEATON1976
noticed a small oil leak by my oil filter. the weather by me dropped to 18 degrees and I wondered if the weather had an effect on the seal of my filter.
Jan 7, 2010 at 12:03 PM
JESIRBY
  • 10 POSTS
normally the cold weather should not effect the oil filter seal unless the vehicle has set for a period of time or the filter was not top grade then you can get a weathered seal or it will shrink. have you tried replacing your filter or checking for debris under the seal.
Jan 7, 2010 at 3:12 PM
