1997 Oldsmobile Bravada ABS Light on, No AC/Heater fan, no
1997 OLDSMOBILE BRAVADA
ATRUEGNTLMN
Electrical problem
1997 Oldsmobile Bravada 6 cyl Four Wheel Drive Automatic
My aunt has asked me to look at her 97 olds. Barvada It seems that the ABS light was coming on and for whatever reason would kill the ac/heater fan from working. It was doing this off and on at first, but now is on all the time. She has had to take the circuit breakers out for the power seats and windows due to them getting so hot you can't touch them (even when they are not in use) I would have to guess there is a dead short some where on the device side of the circuit breakers but I have no idea where to began to look for it. Any help or direction would be great.
Feb 2, 2009 at 8:23 PM
2CARPRO JACK
  • 11,533 POSTS
Locate the ABS unit and try unplugging it, you can just start the car to see if it is still having the same problem.Sounds likk it may have a bad motor in it causing the short
Feb 2, 2009 at 8:47 PM
