1997 Oldsmobile Bravada
1997 OLDSMOBILE BRAVADA
94,600 MILES • 6 CYL • AWD • AUTOMATIC
HCKYRULES219
  • 4 POSTS
When I hit the gas and reach about 20 mph this noise starts that sounds like a cricket. It is geting louder and louder. If i let off the gas the noise goes away but as soon as i hit the gas it starts agin.The noise only happond when i hit the and the truck has to be moving. The will not happond just by reving the engine up. The noise sometimes happonds when i hit the breaks too. I wastold it was a speedometer cable but i was also told that the 1997 does not have a speedometer cable.
Apr 23, 2008 at 8:32 PM
MOPARNUT1393
  • 34 POSTS
check the breaks make shure you have lots of brake pad left you may be to the squeelers that alert you to needing new pads. other than that if you have good pads you may have a bad u-joint some where.
Apr 23, 2008 at 8:54 PM
