if i change out the throttle control sensor will this fix this problem
what does the MAP sensor do?
updated 4-9-10
I am trying get answers to "rough idle" on a 1996 oldsmobile bravada
i have changed out the idle control sensor and that helped a little, i have put a complete tune-up except ignition coil, will changing out the throttle control sensor and the pick up coil help eliminate this problem, i also replaced the battery and air filter.
Also what about replacing the oxygen sensors?
thanks for your help!
Daniel
updated 4-9-10
Daniel
Apr 2, 2010 at 9:10 AM
