1996 Oldsmobile Bravada engin surg/missing
1996 OLDSMOBILE BRAVADA
DANCHYCNER
Engine Mechanical problem
1996 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
car will barely pull its self and then for a breif moment will get power and go then will barely pull its self agen and some times stalls unless you give it a little bit of gas note only stalls when idleing or when at a stop. when I hold my foot on the gas and hold it at 2000 rpm it will some times bounce between 2000 rpm and 3000 rpm whithout me makeing it do so. and it will not go past 4000 rpm when you put it to the floor.
SOME ONE PLEASE HELP ME I AM GOING NUTS TRY TO FIGUR THIS OUT !!!!!
Jan 6, 2010 at 6:58 AM
JESIRBY
  • 10 POSTS
with out knowing your maintance record it could be several things from somthing simple like your fuel filter to the fuel pump. i would start at the fuel filter then.
1 fuel filter
2 fuel injector regulator
3 throttle position sensor
4 air idler assembly if applicable
5 throttle position sensor
6 fuel pump.
or it could be a combination of some or all of the above all parts can be got at any auto parts store and not that exspensive. hope this helps.
Jan 7, 2010 at 3:33 PM
