1994 Oldsmobile Bravada not getting any spark
1994 OLDSMOBILE BRAVADA
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOAFIFY
  • 5 POSTS
well i've done alot to this truck because i lke it so much, i've replaced Coil, EGR Valve, CPI Injector, MAP Sensor, Idol Air Controll Valve, Spark Plugs & Wires, Distibutor Cap & Rotor Button, and had the Ignition Module checked. So if its not New its been checked out. Can someone tell me why i'm not getting any spark. I've also checked the connectors to the Coil, Ign Mod, for voltage and i'm getting at least 10 volts at the "+" and the "C" pins on the Ign Mod. HELP!!
Jan 28, 2009 at 7:30 PM
JNOVACK
  • 723 POSTS
with dist. cap off have someone crank engine over and see if rotor is turning and let me know
Jan 28, 2009 at 7:56 PM
JOAFIFY
  • 5 POSTS
yes rotor button is spining
Jan 28, 2009 at 8:42 PM
JNOVACK
  • 723 POSTS
here are some procedures The symptoms of a defective component within the DI system are exactly the same as those you would encounter in a conventional or HEI system. Some of these symptoms are: Hard or no Starting Rough Idle Fuel Poor Economy Engine misses under load or while accelerating If you suspect a problem in the ignition system, there are certain preliminary checks which you should carry out before you begin to check the electronic portions of the system. First, it is extremely important to `make sure the vehicle battery is in a good state of charge. A defective or poorly charged battery will cause the various components of the ignition system to read incorrectly when they are being tested. Second, make sure all wiring connections are clean and tight, not only at the battery, but also at the distributor cap, ignition coil, and at the electronic control module. Check the cap for tiny holes and carbon tracks as follows. Remove the cap and place an ohmmeter lead on the cap terminal. Use the other lead to probe all the other terminals and the center carbon ball. If the readings are not infinite, the cap must be replaced. SECONDARY SPARK TEST It is imperative to check the secondary ignition circuit first. If the secondary circuit checks out properly, then the engine condition is probably not the fault of the ignition system. To check the secondary ignition system, perform a simple spark test. Remove one of the plug wires and insert some sort of extension in the plug socket. An old spark plug with the ground electrode removed makes a good extension. Hold the wire and extension about 1/4 in. (0.25mm) away from the block and crank the engine. If a normal spark occurs, then the problem is most likely not in the ignition system. Check for fuel system problems, or fouled spark plugs. If, however, there is no spark or a weak spark, then test the ignition coil and the camshaft and crankshaft position sensors. For testing the camshaft and crankshaft position sensors, refer to . TESTING See Figure 1
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800bfaa3_1.jpg
Fig. 1: Ignition coil testing-Distributor Ignition (DI) systems Make sure the ignition switch is OFF Tag and disconnect the wires from the ignition coil. Using a digital ohmmeter set on the high scale, probe the ignition coil as shown in Step 1 of the accompanying illustration. The reading should be infinite. If not replace the coil. Using the low scale of the ohmmeter, probe the ignition coil as shown in Step 2 of the accompanying illustration. The reading should be 0.2-0.5 ohms, if not replace the coil. Using the high scale of the ohmmeter, probe the ignition coil as shown in Step 3 of the accompanying illustration. The reading should be 5k-25k ohms, if not replace the coil. Reconnect the wires to the ignition coil. REMOVAL & INSTALLATION Tag and disengage the wiring connectors from the coil and the coil wire. Unfasten the retainers securing the coil bracket or coil to the manifold. Remove the coil and bracket and drill out the two rivets securing the coil to the bracket. Remove the coil from the bracket. To install: The replacement coil kit may come with the two screws to attach the coil to the bracket. If not, you must supply your own screws. Fasten the coil to the bracket using two screws. Fasten the coil bracket or to the manifold. Tighten the retainers to 20 ft. lbs. (27 Nm). Engage the coil wire and the wiring connectors to the coil.
Jan 28, 2009 at 8:55 PM
JNOVACK
  • 723 POSTS
also make sure firing order is this way All 1994 4.3L engines and 1995 4.3L VIN Z engines Firing order: 1-6-5-4-3-2 Distributor rotation: clockwise
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800bfae6_1.jpg
Jan 28, 2009 at 8:58 PM
JOAFIFY
  • 5 POSTS
i did that test on the old coil and it passed but i bought a new one any way and i get the proper voltage to the "+" and "C" pins on the Ign Mod
Jan 28, 2009 at 9:01 PM
JNOVACK
  • 723 POSTS
ok now pull the plugs and put #1 at top dead center on compression and see were the rotor is at
Jan 29, 2009 at 7:53 AM
JOAFIFY
  • 5 POSTS
it is where it's supposed to be according to the hayes manual
Jan 29, 2009 at 3:08 PM
JNOVACK
  • 723 POSTS
ok you said you changed the coil is it a new one or used one and did you change the Ignition Module they are what give the spark also check the knock sensor
Feb 2, 2009 at 1:22 PM
JOAFIFY
  • 5 POSTS
my pick up coil had shorted out against it's housing in the distributor, which shorted out my new module and coil. I've replaced the pick up coil, and also replaced the module, and coil and now she runs like new thanks for all your help.
Feb 5, 2009 at 5:47 PM
JNOVACK
  • 723 POSTS
glad I could help
Feb 5, 2009 at 7:10 PM
