1994 Oldsmobile Bravada ac copmressor clutch relay
1994 OLDSMOBILE BRAVADA
CDADOVICH
  • 7 POSTS
Air Conditioning problem
1994 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
My ac compressor clutch won't engage on my 94 bravada. I think it is the relay but don't know where it is located. Can you tell me please.
Jun 30, 2010 at 9:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
A/C relay is located on bracket, on right side of firewall
Jun 30, 2010 at 9:32 AM
CDADOVICH
  • 7 POSTS
There are 2 relays on the right side behind the brake booster. A large gray one and a smaller black one. Which of there are the ac relay?
Jun 30, 2010 at 9:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
should look similar to pic below
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2395.jpg
Jun 30, 2010 at 9:49 AM
CDADOVICH
  • 7 POSTS
Is there anyway to bypass the relay to see if that's the promblem? Thank you.
Jun 30, 2010 at 9:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
would require some rewiring..easiest way is to simply swap the relay with another same sized relay on the vehicle.
Jun 30, 2010 at 9:58 AM
CDADOVICH
  • 7 POSTS
Any idea which one to swap it with? The other relays I see are a lot bigger then the one in question. Should like a good idea I just don't know which one to swap it with.
Jun 30, 2010 at 10:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
no would just have to look for them , sorry.
you may also test the relay itself.. we have a great guide on how to test relays at https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Jun 30, 2010 at 10:05 AM
CDADOVICH
  • 7 POSTS
I changed the relay and the compressor clutch still won't engage. Any ideas what else it might be would be great. Thanks
Jun 30, 2010 at 4:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
follow the diagnostic steps below..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2406.jpg
Jun 30, 2010 at 5:00 PM
