1992 Oldsmobile Bravada oil cooler / remote filter
1992 OLDSMOBILE BRAVADA
225,000 MILES • 6 CYL • AWD • AUTOMATIC
JESIRBY
  • 10 POSTS
why does the 1992 olds bravada have a remote filter and can it be removed so i can use a traditional oil filter under the engine.
Jan 1, 2010 at 8:05 PM
The remote filter was a way to help cool the engine oil; thus, help cool the engine. As far as your question, the engine in your vehicle isn't set up for a traditional filter and can't be changed.
If I had to guess, you want to change it because of leaks. They all seemed to leak after a few miles. You can replace the lines or the o-rings if that is the problem.
Let me know if you have other questions and thanks for using 2carpros.com.
Jan 2, 2010 at 9:53 PM
JESIRBY
  • 10 POSTS
I just built and replaced my engine and put a new remote filter set up on, its all brand new does not leak. I wanted to make sure that the remote filter was not a necessity or there where not going to be any clearance issues. I believe that there is a spot for a traditional filter under my engine or a place for an adaptor to convert it over to the traditional filter. Do you have any recommendations for an adaptor I put a standered oil pump and I forgot to consider the remote filter when I built the engine so I did not use a high flow oil pump I want to make sure I get plenty of oil circulation oil pressure is good but I could increase oil pressure and oil circulation by removing the remote filter.
Jan 3, 2010 at 12:04 AM
Honestly, I recommend staying with what you have. It shouldn't have any affect on the pressure and it will help cool the oil. As far as an adapter, the only recommendation I would have is contact a dealer and get a direct fit if one is available.
Jan 3, 2010 at 12:24 AM
JESIRBY
  • 10 POSTS
on a non-remote filter 4.3 engine the book says put in 4.5 quarts of oil for fill up. do you add an extra quart for the remote filter. Or what is recommended.
Jan 3, 2010 at 12:51 AM
I believe they both take the same. Start at 4 1/2. Yours may take 4 3/4 to fill but if I recall corretly, they take 4 1/2.
Jan 3, 2010 at 2:09 PM
JESIRBY
  • 10 POSTS
well after getting under the engine and checking out the remote filter I found out that there is about 2 inch clearance issue between the filter and drive line there is a spin on spot for the filter but it will not fit you would have to do a 4 inch body lift to be able to use a traditional filter set up and it would still be difficult to get the filter in place so not going to happen. Also it took 5 1/2 quarts of oil to top off every thing, the remote filter holds the extra quarts at least that what works for me. but I know why the remote filter is there know.
Thanks for you help
Jan 4, 2010 at 3:45 PM
That makes sense.
Good luck and let us know if you have other questions.
Jan 4, 2010 at 3:57 PM
