2003 Oldsmobile Aurora loss of power/acceleration
2003 OLDSMOBILE AURORA
82,000 MILES • V8 • 2WD • AUTOMATIC
AURORAMAN
  • 4 POSTS
i have tried everything i have been told and my trouble still persists. my 2003 aurora has gradually started to lose power after i got my a/c fixed. prior to that, it felt sluggish and i took it to the dealership. they say they discovered a crack in the intake and fixed it. After that, the car felt like new. my power had come back and i barely skim the gas and car pulled strong. But because of the heat, i got my a/c fixed, and gradually, the power started to fade to the point where uphill, the car decelerate and i have to press the gas hard so it could go, Changed the fuel filter about 4 month ago along w/ putting new spark plug( all 8). Coil pack front/back failed last year 's been changed. new air filter put. . Lastly i have clean my MAF and i noticed a slight increase when accelerating from a stop but only when the a/c is not running. i got a little more power when the a/c ain't running but i used to have power w/ a/c on when the a/c just got fixed for about a week before the power start decreasing.
Aug 17, 2010 at 11:22 PM
Has the check engine light come on? Also, have you checked fuel pump pressure?
Aug 18, 2010 at 11:28 PM
AURORAMAN
  • 4 POSTS
no no engine light so far. the engine sounds good and the speed shifts correctly. But today, it seems like even with the a/c now off , the car still feels sluggish..
Aug 19, 2010 at 1:06 AM
AURORAMAN
  • 4 POSTS
by the way, how could check the fuel pump pressure on my own. Hey but it seems like there was a recall on the fuel tank system assembly for my car of this year..i'm not the first owner, how can i check if this has been fixed before..w/ the dealer..maybe that where the pb comes from??
Aug 19, 2010 at 1:09 AM
Here is a how to for checking fuel pressure. It will require a gauge, but most part stores will lend them to you.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
As far as the recall, take the car to a dealer and they will run the vin and know if the recall has been taken care of.
Let me know what you find.
Aug 19, 2010 at 8:29 PM
AURORAMAN
  • 4 POSTS
ok i will do so..but in the event i don't find any wrong with the fuel pump, regulator or filter, what would be the next step??
Aug 19, 2010 at 9:08 PM
Without the check engine light, it becomes a guessing game. If the engine is running sluggish, I have to ask when the last tune up was, is the catalytic converter starting to plug...
Aug 19, 2010 at 10:31 PM
