TRANSMISSION VALVE BODY WAS REPLACED BY DEALER 7 MONTHS AGO AND SAME PROBLEMS ARE REOCCURING, ERRATIC DOWN SHIFT, HIGH LINE PRESSURE AND HARD UPSHIFTS AND MOST OF THE TIME NO UPSHIFT FROM 2-3RD. ONCE THE VEHICLE IS SHUT DOWN FOR 2 OR 3 HOURS AND RE DRIVEN TRANS SHIFTS OK UNTIL OF COURSE IT DECIDES TO GO WACKY AGAIN WHICH CAN BE WITHIN 1-40 MILES OF DRIVING. TOOK VEHICLE BACK TO DEALER AND THEY STATE THAT THEY FIRST HAVE TO REPAIR INJECTORS 1 AND 3 WHICH ARE SOMETIMES MISFIRING CAUSING ENGINE CODES THAT MAY BE CAUSING TRANS TO ACT UP. I THINK ITS A BUNCH OF HOG WASH TO CHARGE ME $200.00 TO COMPENSATE FOR WARRANTED TRANS REPAIRS. I DO NOT FEEL THAT THE ENGINE MISFIRES THAT ARE NOT EVEN FELT WHILE ENGINE IS RUNNING HAVE ANYTHING TO DO WITH THE TRANSMISSION FAILING AS IT DOES. DO YOU THINK THAT THIS IS TRUE BECAUSE I FIND IT HARD TO BELIEVE. ON ANOTHER SUBJECT THE OBD STATES LOW ENGINE COOLANT EVERY TIME I START THE VEHICLE AND EVEN SOMETIMES AFTER 2 OR 3 HOURS OF DRIVING EXCEPT THAT THE RADIATOR AND THE RECOVERY TANK IS FULL TO SPEC. IS THERE A SENSOR THAT MAY BE FAULTY AND IF SO WHERE IS IT LOCATED?
THANK YOU
THANK YOU
Apr 23, 2009 at 1:03 AM
