2001 Oldsmobile Aurora RPM
2001 OLDSMOBILE AURORA
WVGR20098
Transmission problem
2001 Oldsmobile Aurora 6 cyl Front Wheel Drive Automatic
i think i have a problem with my RPM or something, i have a 2001 aurora olds. every time i accelerate the gas the RPM will go to 2000 just when I'm barely getting up to 25 mile per hour. After I'm at 50 or 60 mph the RPM is stays mostly on 2500. Could this be a problem, also after driving the car at 60 or 70 if i slow down and i try to accelerate the RPM will go down and as it will go up, the car will almost bounce back or as if the machine is forcing its self and then it relives. what could this be?
Oct 30, 2008 at 2:31 AM
Hi:
What ou explained sounds normal. In first gear, the RPM's will rise fast. When at highway speed, the trans is in a much higher gear and 2500 RPM's also sounds right.
Dec 21, 2008 at 11:09 PM
