2001 Oldsmobile Aurora Engine missing
2001 OLDSMOBILE AURORA
137,000 MILES • 6 CYL • 2WD • AUTOMATIC
GRAYERIC
My 2001 Olds Auroa Check engine light is on and is missing really bad,
Had it checked on machine the code said #1 cylinder
was missing,Ichanged all of the spark plugs but it dindn't help
Dec 30, 2008 at 11:23 AM
Is the spark plug wire ok? Are you getting a good spark to that cylender? If you remove the plug, is it wet? Finally, have you checked compression in that cylender?
Feb 19, 2009 at 7:34 PM
