1996 Oldsmobile Aurora Thermostat
1996 OLDSMOBILE AURORA
EVERT
Engine Cooling problem
1996 Oldsmobile Aurora V8 Front Wheel Drive Automatic
How do I change the thermostat on a 1996 oldsmobile aurora
Apr 1, 2010 at 3:46 PM
Fig. 16 Thermostat Removal
https://www.2carpros.com/forum/automotive_pictures/12900_t_5.jpg
1.Disconnect battery ground cable. 2.Drain cooling system. 3.Remove air intake duct. 4.Disconnect radiator housing from thermostat housing. 5.Remove thermostat housing attaching bolts, then the housing, Fig. 16. 6.Remove thermostat from thermostat housing. 7.Reverse procedure install. When refilling cooling system refer to Cooling System/Service and Repair for important cooling system refill information. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Apr 1, 2010 at 3:56 PM
