1996 Oldsmobile Aurora p0300 code
1996 OLDSMOBILE AURORA
122,000 MILES • V8 • FWD • AUTOMATIC
CABLE_187
keep getting this random misfire code. cylinder #2 has an excessive amount of gas going in it . the spark plug was covered in gas. it runs really rough in gear and i get a CEL and when driven the CEL fllashes so i have not driven it since. but i cant figure out what the problem is.
Apr 17, 2010 at 8:37 AM
LEGITIMATE007
  • 5,121 POSTS
that will most likely indicate a bad injector, and will need replacement
Apr 18, 2010 at 10:41 PM
CABLE_187
it turned out to be a bad coil and a defective sparkplug wire. but now the car is overheating. i have only had this car 3 weeks and i have replaced plugs, wires, 1 coil ,changed oil ,and flushed and filled radiator and put in a new thermostat. checked the fans and they work on a 12 volt source . could it be one of the relays cause one of the was replaced right before i bought the car. i am kind of stumped. never had so many things go wrong all at once.
Apr 21, 2010 at 12:40 PM
LEGITIMATE007
  • 5,121 POSTS
well ,if the fans work. and one of the fans come on when the a/c is turned on(it is supposed to) then either the relay to the radiator fan is not good, or the engine coolant temp sensor is not good, either or
Apr 21, 2010 at 7:37 PM
CABLE_187
thanks for replying to me it turned out to be the coolant tank cap seal was bad so a new coolant cap and we are smooth sailing. again thanks for the help it is much appreciated
Apr 22, 2010 at 12:12 PM
