1995 Oldsmobile Aurora Bleeding Brakes
1995 OLDSMOBILE AURORA
112,000 MILES • V8 • 2WD • AUTOMATIC
DOUGLASOQUIST
I replaced the brake pads and rotars on the front wheels and bled the brakes from the front to the back. No air is now coming out of the bleed valves. The brakes are still mushy and it sounds and fells as if there is still air in the lines. Is there any additional proceedure that I missed here?
Dec 27, 2009 at 5:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation! Once the brakes have been manual bled, you will then have to pressure bleed them using a scan tool . Pressure bleeding steps are below...
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1347.jpg
Dec 27, 2009 at 8:53 PM
