Rubbing noise is more pronounced when coasting. Replaced hub bearing last fall. Car was a little low on brake fluid. Filled it to max line and the sound started. Is this as simple as too much brake fluid and the pads are producing a lot of friction on the rotor?
Jun 24, 2008 at 1:04 PM
