This is gonna be long. 04 Alero, 3.4L comes in with no crank. No power to starter solenoid. Check relay, I have both powers (one from igntion switch, one from Park/Neutral switch) no ground from PCM. Ignition switch is sending live to PCM to tell it to crank. All lives and grounds to PCM are good. Changed PCM with a used one. No difference. I bypassed the PCM, with a relay and it cranks and starts but then dies. No security light comes on when it stalls. No oil or battery light either. I cannot communicate with any module with my Snap-On Solus. Sometimes the indicators in the dash don't work. Radio also will not turn on but it has it's power and ground. I am so confused!!! I've spent at least 12 hours already trying this one. Please help me!
Feb 14, 2009 at 1:52 PM
