2004 Oldsmobile Alero need help asap
2004 OLDSMOBILE ALERO
DERRICKAMANDA
Transmission problem
2004 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
the transmission jerks into gear after a few miles of travel, and air conditionair wines alot can you help us witha code to restart the cars cpu?? thank you and god bless
Apr 18, 2009 at 4:48 PM
JERRYGOODWRENCH
  • 77 POSTS
Try changing the tranny fluid and filter. To reset the computer just disconnect tihe battery for 5 min then reconnect. double check the trans fluid level while running in park(hot) and make sure it's good..Also you could have a motor mount problem. That would cause the jerking also...
Apr 18, 2009 at 5:34 PM
