2004 Oldsmobile Alero HARD COLD START
2004 OLDSMOBILE ALERO
TRUDOLPH
Engine Performance problem
2004 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
I REPLACED THE FUEL PUMP ON THE ABOVE VEHICLE WITH A NEW AFTERMARKET PUMP DUE TO MORNING COLD HARD START AND THE VEHICLE STILL DOING THE SAME THING. THE ONLY WAY I COULD GET IT STARTED EVERY MORNING IS TO USE STARTING FLUID AND IT WILL START RIGHT AWAY. ONCE YOU GET IT STARTED IT WILL START FINE EVERY TIME UNTIL I LET IT SIT OVERNIGHT THAN I HAVE TO USE STARTING FLUID AGAIN TO GET IT STARTED. ANY IDEAS OUT THERE?
Jan 15, 2010 at 1:00 AM
PATMX31995
  • 5 POSTS
Its most likey your fuel pressure regulator
They are a common failure on 3.1 and 3.4
Check the vac line going to the regulator for signs of fuel
Apr 8, 2011 at 12:08 AM
