When the a/c is turned on engine RPM increases & dash,steering wheel ,etc. start vibrating.When a/c is turned off,vibration stops. I think the compressor is going out & is dragging,causing strain on the engine as it drives the pulley.I'm hoping it may just be the clutch bearings.Can I replace the clutch without discharing the unit? I do not have a vacum pump & other tools needed for a complete compressor swap.
Mar 22, 2008 at 9:28 AM
