2004 Oldsmobile Alero
2004 OLDSMOBILE ALERO
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
CLARENCE PALMER
car doesn,t heat all the time
Mar 29, 2010 at 4:12 PM
LEGITIMATE007
  • 5,121 POSTS
check/change the thermostat, and check any vacuum hoses going into the firewall for disconnected or cut etc.hoses. if not fixed, make sure you have the correct level of coolant in the system and change the radiator cap. then bleed the coolant system. if you have other questions just ask
Mar 29, 2010 at 4:45 PM
