Electrical problem
2003 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic
i have a 2003 olds alero the batterie is good. i turn it off the other day , 5 mins. later it won't crank. If you jump the starter it will crank but won't start. The little wire on the starter is died in crank position
Thank you
Frank Herber
Thank you
Frank Herber
Jan 26, 2009 at 2:45 PM
