2003 Oldsmobile Alero won't crank
2003 OLDSMOBILE ALERO
FHERB5
Electrical problem
2003 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic
i have a 2003 olds alero the batterie is good. i turn it off the other day , 5 mins. later it won't crank. If you jump the starter it will crank but won't start. The little wire on the starter is died in crank position
Thank you
Frank Herber
Jan 26, 2009 at 2:45 PM
DOCFIXIT
  • 18,828 POSTS
Sounds like you in need of a ignition switch
Jan 26, 2009 at 3:33 PM
