2003 Oldsmobile Alero Suspension
2003 OLDSMOBILE ALERO
RAYHOFF1
Heater problem
2003 Oldsmobile Alero Front Wheel Drive Automatic
How to replace front and rear struts
Oct 7, 2010 at 11:06 AM
MERLIN2021
  • 17,250 POSTS
First you will need to rent a spring compressor, and hopefully you have an air impact to help aid in disassembly? STRUT ASSEMBLY REPLACEMENT Removal Procedure 1.Remove the nuts (1) and bolt (2) attaching the top of the strut assembly (5) to the body (3). 2.Raise and support the vehicle. Refer to LIFTING AND JACKING THE VEHICLE in General Information. 3.Place jack stands under the front crossmember. 4.Lower the vehicle slightly so that the weight of vehicle rests on the jack stands and not on the control arms. NOTE: Care must be exercised to prevent the drive axle joints from being over-extended. When either end of the shaft is disconnected, over-extension of the joint could result in separation of the internal components and possible joint failure. Drive axle joint boot protectors should be used any time service is performed on or near the drive axles. Failure to observe this can result in interior joint or boot damage and possible joint failure. 5.Remove the tire and wheel assembly. Refer to TIRE AND WHEEL REMOVAL AND INSTALLATION in Tires and Wheels. 6.Remove the brake line bracket. Fig. 37: Removing Nuts & Bolt Attaching Top Of Strut Assembly Courtesy of GENERAL MOTORS CORP. 7.Scribe the strut flange. Refer to STRUT AND KNUCKLE SCRIBING. 8.Remove the bolts (6) and the nuts (2) attaching the strut (1) to the steering knuckle (3). NOTE: Care should be taken to avoid scratching or cracking the spring coating when handling the front suspension coil spring. Damage can cause premature failure. IMPORTANT: The steering knuckle must be supported in order to prevent axle joint over-extension. 9.Remove the strut (1) from the vehicle. Fig. 38: Removing Bolts & Nuts Attaching Strut To Steering Knuckle Courtesy of GENERAL MOTORS CORP. NOTE: Care should be taken to avoid scratching or cracking the spring coating when handling the front suspension coil spring. Damage can cause premature failure. Installation Procedure 1.Install the strut (5) into position and install the nuts (1) and one bolt (2) connecting the strut (5) to the body (3). Hand tighten the nuts and the bolt. Fig. 39: Installing Nuts & One Bolt Connecting Strut To Body Courtesy of GENERAL MOTORS CORP. NOTE: Refer to FASTENER NOTICE in Cautions and Notices. 2.Align the steering knuckle with the strut flange scribe mark and install the bolts (6) and nuts (2). Tighten 3.Tighten the nuts to 180 N.m (133 lb ft). Fig. 40: Installing Bolts & Nuts To Steering Knuckle Courtesy of GENERAL MOTORS CORP. 4.Tighten the nuts (1) and bolt (2) attaching the top of the strut (5) to the body (3). Tighten  Tighten the nuts to 25 N.m (18 lb ft).  Tighten the bolt to 25 N.m (18 lb ft). 5.Install the brake line bracket. 6.Install the tire and wheel assembly. Refer to TIRE AND WHEEL REMOVAL AND INSTALLATION in Tires and Wheels. 7.Inspect the front wheel alignment. Refer to MEASURING WHEEL ALIGNMENT in Wheel Alignment. Fig. 41: Tightening Nuts & Bolt Attaching Top Of Strut To Body Courtesy of GENERAL MOTORS CORP. SUSPENSION STRUT DISPOSAL CAUTION:Use the proper eye protection when drilling to prevent metal chips from causing physical injury. 1.Clamp the strut in a vise horizontally with the rod (1) completely extended. 2.Drill a hole in the strut at the center of the end cap (3) using a 5 mm (3/16 in) drill bit. Gas or a gas/oil mixture will exhaust when the drill bit penetrates the strut. Use shop towels in order to contain the escaping oil. 3.Remove the strut from the vise. 4.Hold the strut over a drain pan vertically with the hole down. 5.Move the rod (1) in and out of the tube (2) to completely drain the oil from the strut. Fig. 42: Drilling A Hole In Strut Courtesy of GENERAL MOTORS CORP. STRUT, STRUT COMPONENT AND/OR SPRING REPLACEMENT Tools Required  J 3289-20 Holding Fixture  J 34013-B Strut Spring Compressor  J 34013-88 Compressor Adapter Removal Procedure 1.Remove the strut assembly. Refer to STRUT ASSEMBLY REPLACEMENT. 2.Mount the J 34013-B into the J 3289-20 . 3.Install the strut assembly into the J 34013-B using the J 34013-88 . 4.Compress the coil spring. Fig. 43: Installing Strut Assembly Into J 34013-B Courtesy of GENERAL MOTORS CORP. 5.Remove the dust cap (1). 6.Remove the strut rod piston nut (2). 7.Release the compressed spring (10). 8.Remove the strut assembly from the J 34013-B . 9.Remove the following components from the strut:  The strut mount (3)  The dust seal (4)  The spring seat (5)  The upper insulator (6)  The coil spring (10)  The spring bumper (7)  The lower insulator (9) Fig. 44: Disassembling Strut Assembly Courtesy of GENERAL MOTORS CORP. IMPORTANT: Make sure that the spring seat "flat spot" faces outboard toward the strut mounting bracket, while the strut mount "flat spot" faces inboard away from the mounting bracket, when assembling the unit. Installation Procedure 1.Install the following components to the strut:  The lower insulator (9)  The spring bumper (7)  The coil spring (10)  The upper insulator (6)  The spring seat (5)  The dust seal (4)  The strut mount (3) Fig. 45: Assembling Strut Assembly Courtesy of GENERAL MOTORS CORP. 2.Mount the strut assembly into the J 34013-B using the J 34013-88 . Fig. 46: Installing Strut Assembly Into J 34013-B Courtesy of GENERAL MOTORS CORP. 3.Identify the orientation of the spring seat (1), the strut mount (3) then compress the coil spring. NOTE: Refer to FASTENER NOTICE in Cautions and Notices. 4.Install the strut rod piston nut and hold the strut rod, at the top, from turning. Tighten 5.Tighten the strut rod piston nut (2) to 75 N.m (55 lb ft). 6.Install the dust cap (1). Fig. 47: Dust Cap Courtesy of GENERAL MOTORS CORP. 7.Release the compressed coil spring (10). 8.Remove the strut from the J 34013-B . 9.Install the strut assembly. Refer to STRUT ASSEMBLY REPLACEMENT. Fig. 48: Removing Strut From J 34013-B Courtesy of GENERAL MOTORS CORP.
https://www.2carpros.com/forum/automotive_pictures/62217_MWSnap027_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_MWSnap028_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_MWSnap029_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_MWSnap030_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_MWSnap031_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_MWSnap032_1.jpg
Oct 7, 2010 at 11:29 AM
