How do you change the o2 sencor , and were is it locate,,, does it have 2 sensors and how do you know which to change
Aug 31, 2008 at 3:45 PM
MERLIN2021
CERTIFIED EXPERT
On a V6 you will have 3 of them, one on each BANK, and one after the converter. Bank one is between the manifold and the converter, on the number one cylinder bank, bank 2 sensor one is on the other side, scan for codes and if there is a problem, the scanner will read from the cars computer and tell you which one(s) are bad.
Aug 31, 2008 at 4:05 PM
MISTY14
MEMBER
were is the upstream oxygen sensor located on a 2001 alero 3.4L
Sep 24, 2020 at 11:55 AM
(Merged)
CARADIODOC
CERTIFIED EXPERT
It comes before the catalytic converter. On V-6 engines, '96 and newer, there may be two of them, one for each side of the engine, and in that case they could be screwed into the exhaust manifolds. When there's only one upstream sensor, it is often screwed into the exhaust pipe right in front of the catalytic converter.
(Merged)
MISTY14
MEMBER
Can you send a picture of were the upstream oxygen sensor is.
(Merged)
CARADIODOC
CERTIFIED EXPERT
This is from Mitchell On Demand. It's the only diagram I can find with an oxygen sensor, but there is likely another sensor on the front manifold. You can get the same information by clicking on the "Repair and Service" tab on the top of this page, then on "Manuals".
Image (Click to enlarge)
(Merged)
CARADIODOC
CERTIFIED EXPERT
Try this.
(Merged)
LPSHAW
MEMBER
1 POST
Pulled the 02 wire's out of the plug, duh me. the two wires coming out of the sensor is black and the other one is white.. the connection plug wires on the wiring harness is black and the other one looks like blue with a white stripe. does black go to black? Thank you
Sep 24, 2020 at 11:56 AM
(Merged)
DANNY L
CERTIFIED EXPERT
Hello, I'm Danny.
Yes, You are correct. black to black and white to blue. Here is a wiring check tutorial if needed:
