2003 Oldsmobile Alero hard starting
2003 OLDSMOBILE ALERO
SLIMS AUTO
Engine Mechanical problem
2003 Oldsmobile Alero 4 cyl Two Wheel Drive Automatic
I have a 2003 Olds Alero with a 2.2 motor. I have replaced the fuel pump twice. It was taking too long to crank after sitting also whtia fuel gauge hooked up the guage goes to 20 it has a rough idle for 4 sec then it jumps to 40 and smoth out, at fuel filter I have 60psi and if i disconnect the return line and block it it cransk right up.
Nov 9, 2008 at 2:22 PM
Inspect and test the fuel pressure regulator
Nov 9, 2008 at 3:01 PM
