2002 Oldsmobile Alero oil leak at oil pressure sensor
2002 OLDSMOBILE ALERO
110,000 MILES • 6 CYL • FWD • AUTOMATIC
1DOMINO
The oil pressure sensor is leaking oil. Is this something that is easy enough for me to replace? I have one good arm right now due to injury. Do they sometimes just need to be tightened? Does the oil need to be drained prior to job? Thanks, Rick
Apr 29, 2009 at 6:56 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:a913586502="1domino"]Engine Mechanical problem
2002 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic 110000 miles
The oil pressure sensor is leaking oil. Is this something that is easy enough for me to replace? I have one good arm right now due to injury. Do they sometimes just need to be tightened? Does the oil need to be drained prior to job? Thanks, Rick[/quote:a913586502]
Hi Rick,
No the oil doesn't need to be drained. You can try tightening first. But would have new one in hab=nd just in case.
Apr 29, 2009 at 7:02 PM
