REMOVAL PROCEDURE
1.Remove the starter.
2.Disconnect the crankshaft position (CKP) sensor harness connector.
3.Remove the CKP sensor bolt.
4.Remove the CKP sensor.
INSTALLATION PROCEDURE
1.Inspect the CKP sensor O-ring and lubricate with a mineral based grease.
2.Gently insert the CKP sensor into the block.
Dec 29, 2009 at 8:36 PM
