2001 Oldsmobile Alero idle air control valve
2001 OLDSMOBILE ALERO
FREAKGURL182_87
Engine Performance problem
2001 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
where is the idle air control valve locarted at?
May 16, 2010 at 5:02 PM
The IACV location see item no.2 below
https://www.2carpros.com/forum/automotive_pictures/12900_iacv_16.jpg
May 17, 2010 at 12:44 AM
AZNGOTHIC
What is the name of the part #6 in that pic?
May 31, 2010 at 11:43 AM
AZNGOTHIC
Never mind. I found it. Throttle Position Sensor. So now my question is....I want to test it to see if its bad or going bad. I've done this before on a different car many years ago. I remember its basically a variable resistor that sends the ecu signals to know what position the throttle is at. What I don't remember is which prongs I need to put the ohm meter on and what its suppose to read out. Any ideas?
May 31, 2010 at 2:11 PM
