Engine problem
2001 Oldsmobile Alero Engine Size unknown Front Wheel Drive Automatic 100000 miles
When i start the car it runs fine, but when i push the gas it stutters a little bit and when i give it more gas it will try to stall. the car will not go over 2000 rpm without straining the motor or cutting off. when i took the air filter system off i noticed oil everywhere inside. i then checked the oil and it was 2 quarts high. i then drained the oil and that made it a little better. could the oil have clogged something. My guess is either the cat converter is plugged up or it might need new plugs from the access oil. There were no signs of head or head gasket problems. Please get back to me as soon as possible. ty scmechanicguy
Jan 5, 2008 at 6:17 PM
