2001 Oldsmobile Alero brake lights
2001 OLDSMOBILE ALERO
JOHNCHARLES
Brakes problem
2001 Oldsmobile Alero 4 cyl Two Wheel Drive Automatic
the brake lights on the rear window work but not the brake lights on the car i changed the fuses and bulbs
Mar 1, 2009 at 7:01 AM
JDL
  • 16,098 POSTS
Use a testlite on the bulb socket, have a helper step on the brake, see if there is any voltage. If you want to probe the wire, for the left side, should be dark blue.
The circuits are wired through the left i/p junction block.
Mar 1, 2009 at 9:52 AM
