I bet you're right that it's the O2 sensor. Since the check engine light isn't coming on, it could just be that the sensor is dirty but other than that nothing is wrong with it. If it's covered in dirt or grease etc, then it's probably not getting the right reading of oxygen and therefore sending more (unneeded) gas to the engine. So if it's the O2 sensor, you should probably get it replaced, but if you're short on money or something, I bet you could just get it cleaned and then it would work right again. (I'm not sure though). Also, about the gas mileage between your car and the Grand Am, I looked it up and the original fuel estimates according to fueleconomy.gov are the same for a 2001 Alero and a 2001 Grand Am, 21mpg city and 32mpg highway. The "new, more realistic" estimates are the same too (19mpg city 29mpg highway). Also one more tip to get better gas mileage once you fix whatever is wrong right now is to use synthetic oil. I've read that it can increase mpg by about 2 or 3 compared to conventional oil and it also lasts longer. (I haven't tested it myself yet though since my old non synthetic oil doesn't need to be changed yet in my car)
Aug 14, 2008 at 12:53 AM
