2000 Oldsmobile Alero Starter motor
2000 OLDSMOBILE ALERO
DAVID KIRK
Engine Mechanical problem
2000 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
Starter motor sounds like its spinning but not engaging the motor.
Jul 18, 2009 at 8:53 PM
JDL
  • 16,098 POSTS
Hello, is the starter loose? Can you tell if the starter is kicking out the pinion gear, key in the crank position? There is probably a dust cover for the flex-plate, underneath, I'm not sure if you can see the pinion gear from there?
Jul 19, 2009 at 8:55 AM
