Engine Mechanical problem
2000 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic
We have gotten new gaskets for the cylinder heads, new piston rings, new gaskets for the manifolds, new oil and water pump. Put everything back together after a second time and still there is no compression getting into the cylinders. Electrical is fine as is the ignition switch, its just there is absolutely no compression getting into the cylinders.
Jun 27, 2010 at 4:50 PM
