2000 Oldsmobile Alero headlight replacement
2000 OLDSMOBILE ALERO
170,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGDDY04
how ecactly do i access the bulb to change the headlight
May 18, 2010 at 8:51 AM
You should be able to from under the hood. If you can't, check for two metal slides on the rad support near the light assembly and pull them up. That should detach the headlight assembly so you can pull it out and replace the bulbs.
Let me know if this helps.
May 18, 2010 at 1:39 PM
